saffyre said:Im seriously tempted on getting a 22 inch tft. I am wondering tho how games will look as my 6800GT isnt going to be running games at a nice res for the monitor. Are games likely too look terrible runnning at a low res on a monitor of that size.
You can work it out by dividing 1280 by 960 which gets you 1.33 which is 4:3 expressed as a ratio. So it's not widescreen no because your screen is 1680*1050 which is 1.6 or 16:10 as a ratio.Shaddow said:I found I had to drop the resolution of FEAR down to
1280x960 (is that widescreen?) and even then it stutters a bit , I'm running everything maxed.
WildgooseUK said:Hashcake,
What resolution setting do you have for the Xbox 360,running on the Asus MW221 because I just received my monitor and looks superb with Vista using the monitor's native resolution 1680 by 1050.
fish99 said:I know you didn't ask me but I'm gonna have a go at answering that if that's ok.
On a 1680*1050 screen, the best resolution for your 360 is actually 1280*1024. You're probably thinking "that's 5:4 not 16:10" but after setting the resolution you go into format and set it to widescreen, and then it looks perfect, a full widescreen view and everything in it's proper proportions, and it's 33% more pixels than 1280*768 and 42% more pixels than 1280*720, and it does look noticeably sharper. It also means the image doesn't get vertically stretched so you get the best picture quality.
WildgooseUK said:Hi there,
I successfully changed the resolution on my Xbox to 1280*1024 and agree with what fish99 said.But,what other settings do you recommend regarding the colours and image quality to get the best out of the Xbox 360?
Plus,I have the Overdrive disabled.
