It's been a long time since I've looked into a new build so I was hoping one of our hardware gurus could take a look at this spec? I'm looking for performance, overclocking capability and future proofing but I'd prefer not to spend more than £1,400. Having said that, value for money is the main thing for me so I can go above if the gains are worth it.
Here's what I'm looking at, the only things that can't be changed are the graphics card as it's already been ordered for £20 less
p), and I'm pretty certain I want the i7 4770K.
YOUR BASKET
1 x Powercolor Radeon R9 290 PCS+ OC 4096MB GDDR5 PCI-Express Graphics Card £379.99
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £269.99
1 x Samsung 250GB SSD 840 EVO SATA 6Gb/s Desktop Kit - (MZ-7TE250KW) £160.99
1 x Gigabyte Z87X-OC Intel Z87 (Socket 1150) DDR3 ATX Motherboard £158.99
1 x Corsair Hydro H100i High Performance Liquid CPU Cooler (CW-9060009-WW) £99.95
1 x Corsair CS750M 750W Semi-Modular 80+ GOLD Certified Power Supply (CP-9020078-UK) £79.99
1 x TeamGroup Xtreem LV 8GB (2x4GB) DDR3 PC3-21300C11 2666MHz Dual Channel Kit (TXD38G2666HC11CDC01) £69.95
1 x Corsair Graphite Series 230T Compact Mid Tower Case Windowed - Grey (CC-9011040-WW) £66.95
1 x Western Digital Caviar Blue 1TB SATA 6Gb/s 64MB Cache WD10EZEX - OEM ** Single Platter ** HDD £52.99
Total : £1,349.39 (includes shipping : £8.00).
I think a 650W PSU would be enough but I'd like to be covered for running a crossfire setup in the future, I guess a 750W would be OK for that? And I keep seeing Seasonic or SuperFlower being recommended but I've never had any issues with Corsair, is it worth spending a bit more for one of those?
Cheers!
Edit: It looks like I'll have to mount the fans for the H100i on the outside of the case if I go with the 230T which isn't ideal.. Any recommendations for a smallish case but big enough to accomodate the H100i and a couple of graphics cards 267mm long?
p), and I'm pretty certain I want the i7 4770K.YOUR BASKET
Cheers!
Isn't that RAM worse though, DDR3 PC3-17100C11 2133MHz for the same price as PC3-21300C11 2666MHz? And why is the Seasonic better, more reliable?
