That’s without monitor can get that later.
Which monitor will you be getting? The resolution and capabilities of the monitor are critical to speccing the GPU.
With £2K for the system unit alone the world is your oyster. You can afford a RTX 2080 Ti - great for 3440x1440 and 4k gaming - and generally high-end components. The case is a placeholder really as they're very much a matter of personal taste.
My basket at Overclockers UK:
- 1 x AMD Ryzen 7 3700X Eight Core 4.4GHz (Socket AM4) Processor - Retail= £299.99
- 1 x Corsair Vengeance LPX Black 16GB (2*8GB) 3600 MHz AMD Ryzen Tuned DDR4 Memory Kit= £79.99
- 1 x Bitfenix Formula Series 750W 80 Plus Gold Power Supply= £82.99
- 1 x Arctic Silver 5 Thermal Compound (3.5g)= £6.49
- 1 x Arctic Silver ArctiClean Thermal Material Remover and Surface Purifier - 60ml Kit= £6.95
- 1 x Fractal Design Define S Midi Tower - Black= £74.99
- 1 x be quiet! Dark Rock Pro 4 CPU Cooler= £84.95
- 1 x Zotac GeForce RTX 2080 Ti Gaming 11264MB GDDR6 PCI-Express Graphics Card= £889.99
- 1 x Asrock X570 Pro4 (AMD AM4) DDR4 X570 Chipset ATX Motherboard= £169.99
You'll need to add a cheap Windows license and a Sabrent Rocket SSD, both available elsewhere. You could easily upgrade to the 12 core Ryzen or treat yourself to a Ducky Shine mechanical keyboard.
The monitor to go with that should be one of these two:
Thanks for that very much appreciated looks a good quality build ! How many years would you get out of that ? In terms of graphics advancing !
Buy, then never look at prices again until you’re shopping for a replacement or upgrade.Problem is, when you buy something, it's already out of date, if you wait for the next big release, it's then out of date, as the manufacturers are already working on the next gen.
Buy the best you can to fit your budget now and it will last you.
Cheaper but still excellent HSF, the 3700X isn't a heat monster, the Dark Rock Pro 4 is a stellar bit of kit if you're happy to pay the extra though.
As I said in my earlier reply, the OP can afford high-end kit and this is one area where overkill benefits.
Good call on the PSU - I'd missed that the one I quoted wasn't modular. And I'm not so sure about the triple-fan GPU. My own experience with a triple-fan 2080 Ti hasn't been that good. I went for Zotac because of their warranty and UK RMA.
2080 Ti is pretty much no bang-per-buck, just gangbanged-to-butt-by-Nvidia product.How many years would you get out of that ? In terms of graphics advancing !
Except for lack luster amount of IPS choises 2560x1440 selection is good.That’s without monitor can get that later.
Low end Asrocks have super inefficient wimpy trash VRMs for X570:AI prefer the Aorus Elite for £30 over the above Asrock, but I'd recommend looking up reviews for both as the Asrock might be fine for you.
Corsair RM PSU costs more but is fully modular and comes with a 10 year warranty. The Formula Gold listed above is a great PSU (I own one myself), but it isn't modular and the cables are quite long and can be unwieldy for a windowed build.
We should note here that Elite caps, which are widely used in the RM650, might be manufactured in China, but Elite is a brand of Chinsan. The latter is a Taiwanese company, with factories in China, and provides products to several high-end brands including two well-known ones. This means that Elite caps are of good quality and you shouldn't be afraid, in any case, of their Chinese origin. Sure there are enough Chinese factories with low production standards, and when it comes to capacitors, this can lead to terrible results. Nevertheless, Elite products have been proven reliable so far, and this is why most brands prefer them when it is too expensive to use Japanese caps.
