Gaming PC Build Upgrade £1100 Budget advice
5 Jul 2015
Hi,
I've just noticed my core PC build is now 3 years old to the date so surely that's worthy any update.
I'm looking at a budget of £1100 and would love to get some advice.
Current spec is:
  • Gigabyte Aorus GTX 1080 Ti 11GB
  • Gigabyte X99M Gaming 5 Motherboard
  • Intel i7 5820k
  • Avexir 16GB DDR4 2400Mhz
  • Corsair Carbide 300R Case
  • 250GB - Samsung EVO SSD
  • 500GB - M2 Samsung 970
  • 2TB SATA 7200 rpm
  • SuperFlower FX 650W '80 Plus Bronze PSU
  • Dell Ultra HD 4k P2715Q 27 Screen
Thanks in advance.
Ah, will hold on to my cash.
What about upgrading the ram to perhaps 32Gb and something a bit faster?
I'm also thinking about upgrading my case as it's a little tight with the GPU and sometimes the temps get around 70 and the fans get quite noisy.
