gaming pc for about 2k
3 Aug 2008
Nottingham
had my current pc since may 2011 water cooling broke few months ago and the graphics card is about to die
not sure if its worth saving anything other than the bluray rom (want a new case)
want for gaming(1080p) some streaming and video editing
theme green most my stuff is razer
just got a razer tiamat 7.1 so maybe a soundcard?
can spend around 2k got 2 monitors mouse keyboard
sorry for the fast post only get about 5 min before my pc turns off lol
thanks
grant
Hi,
IS this a PC to build yourself?
You just want the tower right? no OS/monitor as you have those.
yes its for me to build just the tower
tryd to make a start between crashes
Zotac GeForce GTX 980 AMP OC 4096MB GDDR5 PCI-Express Graphics Card (ZT-90204-10P)http://www.overclockers.co.uk/showproduct.php?prodid=GX-077-ZT
Gigabyte Z97X-UD3H-BK - Devil's Canyon Core i7 4790K CPU & Motherboard Bundle **£15 Saving + Gigabyte Free Upgrade **Avexir Venom Series 16GBhttp://www.overclockers.co.uk/showproduct.php?prodid=BU-012-GI
Avexir Venom Series 16GB (2x8GB) DDR3 PC3-17200C11 2133MHz Dual Channel Memory Kit (AVD3U21331108G-2CIG) - Green Lighthttp://www.overclockers.co.uk/showproduct.php?prodid=MY-045-AR
Corsair Carbide 540 High Airflow ATX Cube Case - Black (CC-9011030-WW)http://www.overclockers.co.uk/showproduct.php?prodid=CA-143-CS
Creative Sound Blaster Z High Performance Gaming Sound Card - OEM (30SB150200000)http://www.overclockers.co.uk/showproduct.php?prodid=SC-088-CL&groupid=701&catid=11
wanted the retail as its on offer but sold out :(
not 100% on the case and if i should get water cooling
will my old psu be ok? i can always upgrade if i want to sli
I tend to spec 850W PSUs for GTX9080 in SLI (thats if you want SLI) or 750W for GTX970s.
It might be fine tho (especially for a single GFX card), so keep it.
YOUR BASKET
1 x Gigabyte Z97X-UD3H-BK - Devil's Canyon Core i7 4790K CPU & Motherboard Bundle **£15 Saving + Gigabyte Free Upgrade ** £409.98
2 x KFA2 GeForce GTX 970 OC Silent "Infinity Black Edition" 4096MB GDDR5 PCI-Express Graphics Card **WorldWide Exclusive** £289.99 (£579.98)
1 x Crucial MX100 512GB SATA 2.5” 7mm SSD + 9.5mm Adapter CT512MX100SSD1) £162.95
1 x Avexir Golden Blitz 16GB (2x8GB) DDR3 PC3-19200C10 2400MHz Dual Channel Memory Kit (AVD3U24001008G-2BZ1SE) £139.99
1 x Phanteks Enthoo Luxe Full Tower Case - Black £119.99
1 x EVGA SuperNova G2 750W '80 Plus Gold' Modular Power Supply £94.99
1 x Cooler Master Nepton 240M AIO Cooling Solution £79.99
1 x CableMod E-Series G2 & P2 Cable Kit - Black £69.95
1 x Toshiba 2TB 7200RPM SATA 6GB/s 64MB Cache - OEM (DT01ACA200) HDD £61.99
Total : £1,719.82 (includes shipping : ).
YOUR BASKET
1 x KFA2 GeForce GTX 980 "Hall of Fame V2 Edition" 4096MB GDDR5 PCI-Express Graphics Card (98NQH6DND2UZ) £529.99
1 x Asus X99-S - Intel Core i7 5820K Six Core CPU & Motherboard Bundle ***£30 Saving*** £517.98
1 x Panram Ninja-V 16GB (4x4GB) DDR4 PC4-19200C15 2400MHz Quad Channel Kit (PUD42400C154G4NJW) £229.99
1 x SK Hynix 512GB SSD SH910A SATA 6Gbps Solid State Drive (HFS512G32MNB-2202A) £164.99
1 x Phanteks Enthoo Luxe Full Tower Case - White £129.95
1 x EVGA SuperNova G2 850W '80 Plus Gold' Modular Power Supply £114.95
1 x CableMod E-Series G2 & P2 Cable Kit - White £69.95
1 x Phanteks PH-TC12DX CPU Cooler - Black £44.98
Total : £1,881.26 (includes shipping : £13.75).
You sure about the green braided cables, you technically don't need any extra cables but I included them for the "looks"
If you like green then you like green.
But I think the audio section on the motherboard glows yellow (which would have matched the Avexir golden RAM).
But that LED can be turned of in the BIOS i think along side the audio section to use the separate sound card.
I have one more suggestion and that is to go red+black, and use a Z97 Sniper board from Gigabyte that has a creative sound chip already on the board and fancy capacitors etc.
YOUR BASKET
1 x Palit GeForce GTX 980 Super JetStream 4096MB GDDR5 PCI-Express Graphics Card (NE5X980H14G2-2042J) £439.99
1 x Intel Core i7-4790K 4.00GHz (Devil's Canyon) Socket LGA1150 Processor - Retail £281.99
1 x Avexir Core Red Series 16GB (2x8GB) DDR3 PC3-17200C11 2133MHz Dual Channel Memory Kit (AVD3U21331108G-2CIR) - Red Light £129.95
1 x Gigabyte G1.Sniper Z97 Intel Z97 (Socket 1150) DDR3 ATX Motherboard £124.99
1 x Corsair Carbide 540 High Airflow ATX Cube Case - Black (CC-9011030-WW) £104.99
1 x Corsair Hydro H110 280mm High Performance Liquid CPU Cooler (CW-9060014-WW) £91.99
1 x CableMod E-Series G2 & P2 Cable Kit - Black / Red £69.95
Total : £1,373.80 (includes shipping : £12.50).
You need X99 boards+CPU for that, the raw clock speed of the 4790K vs a 5820K will be quicker for games.
The 17 4790K still has 8 threads vs the 12 of the 5820K.
found a problem the red and black cables are out of stock lol
YOUR BASKET
1 x Inno3D GeForce GTX 980 "iChill Herculez X4 Air Boss Ultra" 4096MB GDDR5 PCI-Express Graphics Card (C98U-1SDN-M5DNX) **OcUK Exclusive** £449.99
1 x Intel Core i7-4790K 4.00GHz (Devil's Canyon) Socket LGA1150 Processor - OEM £269.99
Total : £1,371.79 (includes shipping : £12.50).
red cables
YOUR BASKET
1 x CableMod E-Series G2 & P2 Cable Kit - Red £69.95
SP range from Corsair which are optimized for static pressure.
Obviously in the 140mm size for the H100 or 120mm for the H105 and others.
