Ok I need some questions answered for me, It would be a lot of help if they were
Motherboard:
Asus P8Z77-V PRO
Flash:
1. Do I upgrade my motherboard B.I.O.S before I put all the system components in?
2. How do I upgrade, Do I use my USB flash drive?
3. How do I check for my BIOS Version, Do I need to boot up my PC after I put everything in it and in the case?
4. Do I have to upgrade?
Is there anything else I need to know?
I'll be making my PC in the kitchen, my table on top is a material called For Mica, Is it safe to build on there or is it conductive?
Fans:
Front: 230*30 mm red LED
Top: 200*30 mm fan *2 (One optional)
Side: 200*30 mm fan
Rear: 140*25 mm fan
Which ones should I plug into the MOBO?
What/how should I connect these?
(Where do I connect the Red connector for the Rear Fan?)
(Whats the connector named number 2 for/where does it go?)
I know the 4 Pin molex connects to the PSU and the other Molex gets connected from the PSU.
Sorry if there is too much, I'm just trying to make sure of certain things.
. Motherboard:
Asus P8Z77-V PRO
Flash:
Fans:
Side: 200*30 mm fan
Rear: 140*25 mm fan
