Gaming Problems...
9 May 2012
Surrey
Hey guys,
just got my new pc from overclockers :D
just got a small problem... when im playing games it keeps taking me out of the game and put me on the start screen (as if ive just pressed the windows button)
Anyone got any ideas what might be causing this?
cheers
try pressing ALT + TAB and switching back to the game, then press ALT+ENTER to maximise the game from windowed screen to full screen.
the ALT+Tab ALT+ENTER didnt work :(
yep all games and no i havent tried a different keyboard ill have to try tht
thx for the suggestions
Do you have sticky keys turned on?
Press shift 5 times, do you hear a beep? You should turn sticky keys off on a gaming pc.
the game doesnt crash i can just click on it and the same thing happens 30 secs later, i do use a tp link wireless adapter u think it could b sumthin to do with tht?
ok, i think ive cracked it, I think it was sticky keys, it was off but i also unchecked the box in the settings which makes it come up after pressing shift 5 times and just played WoW for about 30 mins with no problems
Thanks for the help everyone!
