Hey everyone, I was looking for some advice on a pc I was thinking about building. I was hoping to use the system for gaming as well as general web browsing and some school work. I've come up with the current spec for it and was hoping for some comments on whether it would be appropriate for my needs and whether all parts would definitely be compatible. At the moment I already own a Western digital 2.5" hard drive and a copy of Windows 7 home edition and was looking to spend around the £1000 mark if not slightly less. The SSD is not a necessity although it would be nice to have but I am willing to drop it depending on the price of the build. Any help is appreciated many thanks in advance!
CPU: Intel i5-3570K 3.40GHz (Ivybridge)
Mobo: Gigabyte Z77X-D3H
CPU HSF: Corsair A50 High-Performance CPU Cooler
RAM: Corsair Vengeance Low Profile Blue 8GB 1600MHz DualChannel
GPU: KFA2 GeForce GTX 670 EX OC 2048MB GDDR5 PCI-Express Graphics Card
HDD: Western Digital (WD) Scorpio Blue WD5000BEVT 500GB 2.5 inch Internal SATA Hard Drive (already own)
SSD: Crucial m4 128GB 2.5" SATA-IIISolid State Hard Drive
PSU: Corsair HX 750W ATX Modular SLI Compliant Power Supply
Case: NZXT Switch 810
OS: Windows 7 Home Edition 64-bit (already own)
I should probably add I've never built a pc from scratch before but have had some limited experience replacing parts and fiddling around in PCs I found around the house.
Look forward to any help people can give
also it's a bit cheaper than the Asus
