Hi all,
After some time out from building rigs, I've offered to help a friend build a gaming PC. Their budget is £800 and they don't need any peripherals.
They are planning to get a 1080p 144 Hz monitor and will play Fortnite and other shooters.
Here’s the spec I’m looking at;
MSI B450M Mortar MAX (Socket AM4) DDR4 mATX Motherboard £88
AMD Ryzen 5 2600 £110
Zotac GeForce RTX 2060 £280
Corsair TX650M 650W 80 Plus Gold Semi Modular £80
Samsung 860 QVO SSD 2.5" SATA 6Gbps 1TB £110
Patriot Viper Steel 16GB (2x8GB) DDR4 PC4-28800C17 3600MHz £90
Will get a case for around £50 which takes the total to around £800. No operating system included but I do need to check on that.
Feedback and thoughts would be much appreciated.
Thanks
Ben
Thanks
Ben
