Gaming tower for £400?
27 Jul 2005
The Orion Spur
Building a system for my brothers friend for his birthday, he has a budget of £400, the best I could come up with was the following which is £57 over budget but just felt anything less was too much of a compromise,
What do you think?
Can anything be done any cheaper? AMD?
An i3 chip would bring the cost down a lot, would there be a big difference in performance?
Thank you.
You could easily get away with an FX6300 set up, to allow a 120GB SSD in the build (Since you're already over). Really can't see an FX6300 and 270 being a compromise.
I'd change that PSU too, I don't think they're all that solid?
Not a fan of OCUK's PSU selection at the moment to be honest, it's the one part I hate ordering from here.
It'd have to be the HX550W you'd go for, the price on that 450W isn't really "value" compared to it.
