gaming/work set up advice please
22 Oct 2002
I've bought a AW3225QF for my main landscape screen for work and gaming.
I intended to have a plan view screen next to it. The monitor i was looking at for that was the Dell U2723QE UltraSharp 27 Inch. Then i saw the LG UltraFine Monitor 32UN88AP. They are both about the same sort of price. However the LG is a 32 inch, which might be a bit big. I'm planning on having them on desk arms so i can adjust.
If you are having your main monitor in front of you, the its the size of this that determines the angle you have to turn to in order to view your second monitor. Therefore, in terms of setup comfort, the size of the second monitor makes little difference. Personally I would go for another 32" because you get more screen real estate and it will be easier to see things out of the corner of your eye. So I would get the LG, especially as it looks very adjustable, although personally I would prefer a standard monitor stand for convenience. They both look reasonable choices though, I don't think you can go wrong.
thanks very much for that answer.
