I would change the cpu to the 9800X3D.
As mentioned above why such an expensive board ? You could get something like an MSI X870/E Tomahawk for much less.
There are new graphics cards out from Nvidia at the end of the month if you are not in a rush. Not sure I would pay £800 for a last gen card. The new AMD cards are also due Q1 2025.
You can get a 2TB SSD like the WD Black SN770 for less. A 1TB isn't much for a gaming pc.
Also W11 can be bought for around £10 from key sites. Mine has been working fine since June 2023.
Also 6000MHz CAS30 is the sweet spot for AMD.
Order Kingston FURY Beast EXPO RGB 32GB (2x16GB) DDR5 PC5-44800C30 6000MHz Dual Channel Kit now online and benefit from fast delivery.
www.overclockers.co.uk
