- 18 Oct 2002
- Disley, Cheshire
First post here guys. Currently doing up my granddad's old house and as I don't have an ounce of DIY competence in me, it is proving very expensive
We are having a new kitchen fitted next week. However, before the units are fitted I want to ensure that the room is as draft proof as possible.
At the moment, as can be seen in the below pictures, there is a fair gap between the floorboards and walls. Whilst some of these areas will be covered by the base units, others will only be covered once the Karndean floor has been laid and skirting boards fitted. However, I want to get the gaps filled even behind the base units as the room has apparently always been pretty cold.
What is the best way to go about this? I had thought expanding foam but given what I have said already about my knowledge, I felt I should check!
Would be grateful for the assistance, thanks.
