Garage door controllers - Why no manual ?
10 Dec 2019
I am looking for help on how to reset a garage door. Its a roller door (Novorol) and after replacing 1 of the lifting brackets the door now only opens half way. Also when it closes it goes to the floor but doesn't Auto switch off. I have a control unit on the wall however I do not have the instruction manual and cannot find it online. Can anyone help out ?
a quick google suggests the door is by Novoferm and a further google of that finds multiple options for novoferm/novoroll doors. you spoken to the company that fitted them originally?
By the sounds of it your limits are out look on the motor you should see a flex coming out and you will see 2 grub screws each with an arrow 1 pointing towards and 1 away with a plus and a minus that's how you adjust the limits
That's if it's a 230v tube motor
Post some pics
Industrial door engineer
