Garage flooring - Recommendations
20 Nov 2005
Redditch
Evening all
Finally getting round to redoing the garage into a bit of a mancave.
Planning on getting flooring in the form of tiles, looked at previously recommended suppliers such as Bigdug & The Floortile Centre but wondering those of you who have gone the same route, who have you used & how good/bad have they been?
I guess it depends on what you want to do. I bought some pretty cheap ones from Screwfix and tbh they are great for what I need. I have my bikes in there, some weights, a bench, and do a fair bit of working out in bare feet and its fine. My garage ain't huge but It probably cost me about £120.
I'm sure you can get better quality but it depends on what your budget is and use case.
I laid Mototile Motolock tiles in my garage 5 years ago and they've held up great
I've used their flooring for a few years and it's been perfect.
+1 for the Duramat. I looked round various pvc tile manufacturers and they were the best priced from what I remember. They've been in a couple of years and been absolutely fine so I don't see why you'd need to pay any more.
My question isn't worthy of a new thread so I'll crash this party instead...
Has anyone come up with an easy solution for a poorly laid concrete floor? My garage floor is, in places, rough as hell so I doubt tiles will sit nicely on it. I can chisel off the off high spots but generally the finish is pretty poor.
Self-levelling compound?
