Garage - Humidity & Temperature Sensor (SMART)
8 Mar 2024
UK
Having some rather big damp issues in the garage (external to the house).
Does anyone have any recommendations for a SMART temperature and humidity sensor that will log the data?
Out of interest what sort of functionality does it give you?
To control the heating I imagine?
Home Assistant? I can do whatever I want really, such as keep the bathroom fan on until humidity is below a threshold. Or put the heating on. Whatever HA supports really.
I use the tuya £5 from AliExpress. Works via WiFi, mine are connected to Home assistant but they also connect to the tuya app and everything is logged in there also.
Tuya New WiFi Temperature Humidity Sensor Smart Life Backlight Hygrometer Thermometer Sensor Support Alexa Google Home Assistant
Thanks for this. Much cheaper than the one I have got from Amazon.
The link doesn't work actually - can you point me in the direction of the page that has the working one if possible?
Hopefully that works..
If not search for tuya WiFi temperature & humidty sensor , should be a little white box with coloured screen. The seller has sold 10,000+ and it's currently £6.08
Tuya is an IOT platform so presumably it'll be some generic sensor that uses tuya. My kitchen plinth heater it tuya too.
