Currently working on improving our little garage as its used to store my track/weekend fun car. It started off life like this:
Garage before shots by James Baker, on Flickr
I have painted the walls white to brighten it up, I will soon be boarding the ceiling and also painting that white and will be putting plastic tiles down on the floor:
Untitled by James Baker, on Flickr
I will also be fitting some kitchen units at the back for storage rather than open shelves.
With this in mind the currently lighting solution is a single strip/batten light in the centre of the garage that doesnt give off a great deal of light. Its ok but I want it to be super bright in there. There is a single switch at each of the garage to turn the lights on and off.
Any suggestions, I was thinking to keep it relatively cheap, would it be possible to just buy two more of the same batten lights and daisy chain those to the existing wiring so it all works off one switch and stick one either end to fill in those gaps?
Garage before shots by James Baker, on FlickrI have painted the walls white to brighten it up, I will soon be boarding the ceiling and also painting that white and will be putting plastic tiles down on the floor:
Untitled by James Baker, on FlickrI will also be fitting some kitchen units at the back for storage rather than open shelves.
