Garage Renovation (Completed)
22 Oct 2004
United till I die
We purchased a house a few months back that although fine to live in, needs a lot of work doing to bring it up to scratch.
When viewing the house, the details stated it had a full working double garage...yet as you can see, to say it was pushing the boundaries of what they can claim in a house listing to the very limit! We managed to knock a large amount of money off the house for the garage alone, knowing the Father-in-law would be capable of bringing it back to life, and so the house was purchased.
It took a couple of months to clear the overgrown garden, plus all the work was to done by the Father-in-law, so on factory shut down three weeks ago, the work commenced. I'll apologise now for the picture quality, but we where away for the first two weeks on holiday so that task was given to another family member.
This is how it all looked on the moving in day, trees had been left to overgrow for the best part of 5-10 years, with the owners claiming the garage was fine apart from a needing new roof, his son had fallen through it fetching a football some years back.
We treated the roof as Asbestos and managed to do the removal ourselves with the correct equipment, the local recycling centre also has a free Asbestos bin. They checked it on arrival and it turned out to be a far less troublesome material, but they also treat it Asbestos in it's disposal. We had a very quick check with a Asbestos removal company, and the work was quoted at around £800, so that's around £750 saved from the word go!
The majority of the trees were removed by myself or a friend who used to be a tree surgeon, yet the ones around the garage needed to be done professionally as they had telephone wires very near and access for dropping was going to be an issue. £400 spend, but that did include removal of a large amount of the green left by the other trees once all the firewood was removed.
About 1/5 of the stuff we had left to remove from the previous owners belongings in the garage, we made him pay for 2 skips, with this lot being left from them. Hired a van for the day at £45 that also helped move all the roof and wood from the old garage build.
Stripping of the wood well under way.
All the roof and old garage now removed.
Wood delivered and the work began.
The doors where refreshed by buying all new moving parts to make it all as new as possible without spending silly money, sadly the paint sent was the wrong colour, we asked for 9001 (Cream) and they sent (9010) Pure White and it was too late when we got home to realise! I'm not sure if it's worth doing Cream or leave it as it is?
Now it's time to get the inside sorted, needs a good clean of all the old cobwebs, and some floor paint I think.
Sadly the garage has had a full sparky installation, but we can't figure out why there's no power. We're going to have to hire a mini digger to follow the cable as there's no power at all coming down from the house, which is a major pain!
Estimated cost at the moment for the work is around £1500, that's not including the beer and tea that we had to supply for two weeks :P
Looking very good, great transformation.
Have a look at Leyland floor paint, I have found it very good, available in many colours, screwfix only stock a few.
http://www.screwfix.com/p/leyland-heavy-duty-floor-paint-frigate-5ltr/88106
http://www.leyland-paints.co.uk/leylandtrade_productdetails.asp?prodid=6
If you isolate the power, you could use a meter to test the cable.
I was just having a look at that very paint now! Can't quite decide if it's worth painting and keeping it as it is, or maybe pricing up some kind of flooring for it as I've seen various threads on foam tiles and such.
The cable for the electric is beyond spade digging deep as we started the garage end where is comes out of the garage wall and soon hit ground that won't shift.
We've a fuse in the house RCD for it and then a separate RCD in the garage (which we've changed all the fuses to no avail) but nothing seems to have worked. We've no clue how or where it enterers the house either at the moment. Tested the garage side cable with a meter and there's nothing so ever getting that far, hence the tracking back now. We even had a horrible feeling it's even possible the cable is actually a dead one that was cut years ago, but then the electric were done in 2007 so I can't see why they would have gone to such trouble as having RCD etc in the garage then.
Genius! Never heard of such a thing, even better the local Jewsons do them, and the guy gives me 40% for being in the Ambulance Service!
Thanks ++!
:o
You will need the CAT3 Genny Signal Generator as well, as the cable is dead, & the scanner can't detect a signal.
Years since I had one & used one, isolate cable from the mains, connect the Genny to the earth conductor, you can then detect a signal directly connected or induced into a cable, you'll be told how to use it.
Maybe look at some floor levelling compound instead of painting? My dad's got it and it's brilliant, black flooring that's easy to clean etc and will never chip like paint does.
Great thread.
One of my garages is concrete just like that one, you have genuinely inspired me to restore it rather than demolish and replace it, nice one :)
To echo previous comments.
That is a job well done, also quite surprising how much extra space you appear to have now the trees have been cut back.
As for the white doors, I personally would keep them white, get cream paint next time they need painting ;)
Wow, looks loads better with the timber cladding.
I think the doors would look better in cream, but probably not enough to justify buying another tin and re-painting them now.
