Garage Rolling Door
27 Dec 2006
Northampton
Since clicking on an sponsored ad on my facebook, its now covered in garage roller doors from various companies.
I'm looking to install one as I'm building up my pressure washer setup as garage space is limited so the standard doors will need to go.
I'm wondering whos converted their standard (old style garage doors) to the new roller door styles?
Some companies offer a DIY version and some offer a 'professional install'
I'm not a builder but I want to know if the price difference between the DIY and professional install worth it?
Obviously it will depend on the brand and installer, but I used a local independent and he could buy the doors much cheaper than I could, so it was barely more expensive to get it installed, trim done etc than supply only from the manufacturer/retailers.
His discounts were greater on the electric doors too, so they were much closer in price through him than supply only.
How did you find local independent fitter / supplier?
I got one from Rolling Door Concepts, it was £795 from memory. No issues at all.
Yes thats the company thats been shoved in my face on the ads.
Also is there much difference between them all in terms of mechanics, style, and materials used?
I've had 3 done in 3 years, each just under £1000 fitted by someone else. 2 were Garolla, 1 was a more of a commercial company and the door was heavier and, I think, better. Double skin insulated, it just felt sturdier than the Garolla which feels flimsy and not very secure.
my garage was built with roller doors so not really applicable but the one thing i would say is make sure you actually want an electric one, i went for manual ones and there so much quicker and easier than electric from my usage. As they're sprung they're super easy to put up or down, like 1 or 2 seconds where as electric ones take forever in comparison.
Obviously if you want to open them from the outside with a keyfob in the car it's no use but if its more of a workshop store i think electric ones are a waste of time.
Yes, had a very badly installed up and over when I moved in which failed to shut a couple of times, replaced with roller which has given me loads more wall storage space and extra security and insulation.
I want to convert my 2 up and over doors into one roller door.
I have been looking at these
Little more expensive but seems good quality
Have been looking at these to replace my up and over... How you finding it? Good quality? What spec did you go for? Colour?
No issues with it, went for the anthracite grey and no other options. It's significantly reduced the amount of dust in the garage and as I park my M3 in there it's handy with the fob to close it, also the sensor which tells you when something is in between the door opening so I know how far enough to reverse back.
Resurrection!
I got two cheap Garolla doors after a handbrake incident a couple years ago, the cheapest model just to get us through.
Now I'm wondering if anyone knows if it's possible if I can swap out the wall controller for the one that has single press close? Currently it is a "hold to close" situation.
I've heard they use the same internals as the ANSA units, can I just do a straight swap?
just ordered a double from twf to replace a aging henderson door 4.4metres wide diy fitment will see how fitting goes in about a month :) diy fitment.
on the order with all the electric bells and whistles still worked out 2 .5 to 3 k cheaper.
was going for rollerdor but got swayed by the 5 year guarantee from twf as opposed to the 2 year from roller. as a context supply only for around 1600 compared to house opposite paying 3.5k installed for same door , but without remote and security.....
Resurrection!
Majority of roller shutters can have impulse close provided they have a safety device like a photocell or a safety edge fitted
Resurrection!
I'm looking at getting a garolla garage door. Now you've had them for a while would you recommend? Have you had any problems or faults with them?
just to update me and the wife both in our 60s did the door install in a day and i finished the electrics next day due to having problems adding extra remotes..... my problem not theres will learn to read.
i have no connection with TWF.
but there service was very proffesional from advising on measurement taking, to delivery to up-teen calls to technical because of my lack of reading :).
door works very well and is very quiet.
would recomend to anyone and the price was exceptional. oh and5
year warranty:)
I’m happy with mine, installed last month.
I mean I'm two years in and I can't complain. They're obviously cheap and the insulation isn't brilliant at all but I can't point to any one thing and say "it is bad because...".
It's just that I wish I'd gone for the push to close rather than hold to close. For the price, I cant complain at all.
