Garage Storage Options
31 May 2005
Alfreton,Derbyshire
The house I'm renovating has a 2.5m x 5.5m garage which I would like to make as functional as possible. I'm ideally looking for good quality racking that I can use for storage, but then also somehow incorporate some workspace to do maintenance on, i.e soldering, crafts etc.
Last thing I need is a good way to store four bikes four in total so they're accessible but also using as little space as possible.
I'm sure a few of you will have done a kit out previously, so just looking for advice and ideas
Thanks
Bikes are annoying to store..they just have that awkward handlebar/front wheel issue.
I removed my front wheel so I could swivel the handlebars 90 degrees flat against the wall.
Found a photo of my garage that covers shelf racking, old kitchen reuse, and (just about) bike storage.
The shelves were from Screwfix, about £70 per unit I believe and we got three. Very happy with them.
For the bikes you probably can't make it out, but I just got some basic bike wall mounts from Amazon, black metal bar style. They're cheap and functional but it takes a bit of manoeuvring to get two on one mount.
I got some cheap big metal hooks which i use to put my bike up on the wall of my garage
This is the only pic i have kind of showing it unfortunately
AIL4fc-rZFs-0ihhzdhil6BJjLaseHETGn-1tX_UGeg-AdEX6EHb8DAKNpgZAhaMqYfNnYl0nHtsV3nUvc6GSeh8QrUe3SpDEXUs_tvYMv9KlXtCYqnkXVbXUT-X3TPJKHTuaIWW0IH5V1zqsKD7Qshovc6M6A=w1719-h1289-s-no
For shelving, i've got 1 kit of cheapo 3x cheapo metal and MDF racking off ebay, 1x plastic racking some somewhere and then one fully metal one from B&Q, tbf they've all been really good but the plastic one is probably the most rugged feeling and also the cheapest.
I used one of the ebay ones in half for a work place for my computer, it's fine for that but i wouldn't want to use it as a serios work bench, it'd be ok for crafting but no good if you want to strip a gearbox. I made a proper work bench out of an solid ash table.
AIL4fc8_8if8asw2DXeDdXzJDiBmltGvosIBrLKXZ3UkzJoxWL-rCQJEJJ6_HQwYZdh7xkLrQPOaeUwxwlXn5Og28ErvgVsUdNFPkX9nUntv4IudGfJ5nGci7ZYf-jFFe3YjmiuCJcQDrnrVLLnX16bg_n6g3w=w1719-h1289-s-no
AIL4fc-lVMmLZOmRB1Kbsg3UoApsxRSznR_joLcc2WNq40-lj3GecXt4T0VkefbD9QkTqsclTMQkRoOCQ7W-JuhDYXVUxQCDCDh9KwrcB6nVd88pEJP-Wi2Z8bQCdtT-e_2Z_YeGmbfdH0wUJ9M1Xt8Hp0sOAA=w1719-h1289-s-no
Not sure what the forum has done here, it appears to have scraped my image and re-hosted it; but here is the link:
