Hey,
Need some help planning the foundations of a fairly large garden wall, its 23meters long, 2 bricks thick. My plan is to have 40cm deep foundations (35cm concrete + 5cm hardcore base). It will be about 6 bricks tall, maybe more (will decide later).
Ive just used a laser thing to check the height difference at each end, and the right end of the wall is ~ 13.5cm lower ground than the left, so ive decided to use steps to account for this, by splitting the 23m into 3x7.6cm level steps, which im hoping is the correct thing to do?
This is my current plan:
The problem im having is i dont know how deep each steps need to be? In the diagram i have put the top of each step at the bottom of the previous one, but this is probably way to deep?
Can anyone give me some pointers on how deep the steps need to be to keep everything nice and level?
Thanks,
Jack
Thanks,
Jack
