Garmin Basecamp Help
7 Apr 2004
Hey,
I'm trying to create a custom route using Basecamp and send it to my Garmin sat nav (nuvi 1300).
So, I've made the route in Basecamp and sent it to the device, problem is I can't work out how to use the route on the device. The "Where To" menu only has options for navigating to a point. The destination of my custom route shows up under the Favourites menu, but this is only the end point and not the route :confused:
Anyone by any chance know how the process works?
Thanks.
