Garmin Challenge Me / Virtual Partner
23 Nov 2007
Lancashire, UK
Just a quick question on this for an Edge 200.
If I create a course from a ride I've done, and then use the CM/VP option, at any given point in time is my "ahead/behind" status relative to the speed profile of my original ride, or just relative to the overall average speed of the previous ride vs my average speed so far on this ride?
Just wondering if I can use this as a real-time partner, or whether it's only going to be helpful in the later stages of a ride when average speed is more settled.
Cheers!
I always found the virtual partner really annoying. Since disabling it though I now get the awesome "You won!" screen whenever I finish the route.
Take that, virtual partner!
It depends. Some Garmins use just average speed, others take into account hills and suchlike. I think the 200 just does it based purely on average speed, as I know for sure the 500 does. I think you need the 800 or better for it to account for hills and the like.
Hmm, I'll give it a miss then, the slowest part of the route is the first half for me, so I'll just spend the whole time "being behind"! Thanks for the replies.
