Garmin Forerunner 910XT iPhone sync
6 May 2009
I bought a Garmin 910XT the other day and its working fine however would like to sync it, if possible, with the Garmin Connect app on iPhone.
On the app it shows the Garmin 920XT but not the 910.
The 910 must have Bluetooth to sync with the Bluetooth Ant stick which connects to a PC (it definitely does as shows Bluetooth in the settings)
Is it possible to sync the 910XT with an iPhone using the app? That way I can do my swimming and running then sync it without having to do it with my PC
edit - I have found this but not too sure why it would be needed if the watch and my phone already has Bluetooth - https://buy.garmin.com/en-GB/GB/prod103887.html
AFAIK Bluetooth on the iPhone is limited to Apple accessories - might even just be Bluetooth to handsfree/headsets and nothing else.
Part of the problem by going Apple - they have complete control over what you can do! ;)
Fairly sure the 910xt doesn't have Bluetooth. Just ANT, which is what is just to connect using the ANT usb stick. No way to sync with iPhone unless you buy an ANT adapter for iPhone.
