Garmin Vivoactive 3 HR accuracy
18 Oct 2002
Riding my bike
Does anybody else's Garmin under-read HR at the start of activity? Mine does. I stopped to take my HR manually at 4min in and it was about 160 to 165. My vivoactive 3 was reading 120. After about 8 minutes it was fine. Wierd... Blue line is what I reckon it should have been saying.
Any tips?
Maybe not making good contact with your skin then when you start sweating more that helps it contact. Maybe try wearing the strap a bit tighter or wet your skin under it first?
Is this while walking/running? My VA3 had a habit of recording cadence instead of HR, and it could flip from one to the other during an activity. I remember doing a search and finding others reporting the same. I solved the problem by getting a fenix - it's in a different class!
Tried a slightly tighter strap and a bit of spit on the back of my wrist before I started - worked a lot better... Cheers....
Great stuff. On another note, I'm pleased with the calorie accuracy of my vivoactive 3. I was walking in the high street today doing mostly shopping. Covered 4.3 miles over 2 hours and it said I'd burned 473 calories. According to google "A rule of thumb is that about 100 calories per mile are burned for a 180-pound person and 65 calories per mile are burned for a 120-pound person."
Well I'm 173 pounds so those calories sound correct, give or take. Accuracy is important to me because I want to know I'm not eating more than I should when those burned calories are added to myfitnesspal which basically says I can eat those back.
Garmin seems pretty accurate in estimating calories for me too - for a while I was roughly counting calories and the deficit from Garmin's calories burned estimate correlated well with the rate I was losing weight. I gather that it's more accurate if you wear it regularly and enter details like weight and max HR.
I do suspect that a lot of people considerably overestimate their resting and active calories, and are then disappointed when they don't maintain/lose weight. My 'rule of thumb' is that I burn over 3000 calories per day on average (2000 resting and 1000+ active) and adjust the biscuits and wine accordingly.
optical heart rate is fairly useless when exercidiu. Works well to get resting HR.
Whwn working put if your care about specifics get a chest strap.
Out of curiosity I tried a chest strap this morning and compared the results to the optical HR sensor on the fenix. There was very little in it - comparing the traces the chest strap was a bit quicker to respond to fast HR changes but the measurements were very close (including at the top end).
This was on a trainer bike in Zwift though, so the watch wasn't moving much - I can imagine if you're running with arms bouncing around it could affect an optical measurement. It may also be that earlier generations of optical sensor don't perform so well?
