Gas BBQ regulator connection questions
3 May 2012
Wetherspoons
Hi,
I am after one of these:
https://www.bbqworld.co.uk/char-broil/char-broil-x200-grill2go.asp
I have a 15kg blue colour gas butane gas bottle I run some other stuff on, so want to use the same gas source for the above linked BBQ.
I know that the gas bottle end needs a "21mm clip on" regulator.
What I am not 100% sure about is the BBQ end. You can buy a purpose made adapter to use a gas bottle as linked below, however that is for use with patio gas (propane I guess) and has a 27mm connector which is no good. The BBQ end states that it connects to disposable "EN417 gas canister" so I am guessing that EN417 connection must be somewhat standard?
https://www.bbqworld.co.uk/char-broil/char-broil-adaptor-hose-pb180-x200.asp
So, I found this on ebay:
https://www.ebay.co.uk/p/Universal-...4C3bGVF3tRGjp-pfO0iHr_l1YxlwyD1RoCZyUQAvD_BwE
The gas bottle side is definately correct, but the BBQ end? Think it will fit, or can anyone link an alternative?
