gas conversion on a diesel van
30 Sep 2009
anyone had a van (sprinter, transporter etc) converted to gas? if so, could you tell me about the costs and the pro's/con's?
cheers
not the same as lpg. i have a friend who is a hgv driver (i didn't know that diesel's could be converted) and he said they use natural gas or some sort of hybrid system?
Is this the same as LPG? If so.. I didn't know you could convert diesels?
You can, there are 2 systems, mixed and pure, mixed diesel/gas has issues of minimal savings and the pure lpg requires a spark ignition system fitting in place of the glow plugs and modified pistons.
You can also have CNG compressed natural gas which Northampton runs its busses on (I used to fill my Mondeo CNG at the bus station in Northampton).
CNG can also allow a home filling station, but I think it also requires a spark ignition system on a diesel.
That is the extent of my knowledge, but my CNG Mondeo was cheaper to run than on LPG.
(LPG works like a fume carb/single injector, CNG is metred individual injectors)
what about fill up locations, do you know how many there are around the country (apart from northampton)?
Back when I used it, it was utterly abysmal, but found some info for you, apparently there are 9000 sites in the UK, news to me :)
http://www.gasfuelling.com/alternative_fuels_cng.php
http://www.gasfill.com/
http://aag.bright-site.co.uk/gallery/main.php?g2_itemId=1108
http://www.cngservices.co.uk/natural-gas-vehicles/
http://www.cngservices.co.uk/assets/Articles/nscareport.pdf
EDIT: I urge you to read up about Shale Gas and watch Gasland if you go CNG to ensure it meets with your ethics :) The Fraccing facility near Blackpool appears to have caused 2 minor earthquakes already :eek:
Surely no one actually converts a diesel engine back to spark ignition just to run it on LPG? This would be a huge amount of work which is most unlikely to be economically viable. In fact it would probably be easier to replace the diesel with a petrol engine if you were that desperate to use LPG.
You realise CNG saves approximately 40% in running costs compared to petrol/diesel right? (sorry you said lpg, but cng still requires conversion)
http://www.gill.co.uk/products/digital_ignition/cngconversion.htm
also found a converter for mixed diesel/lpg systems.
http://www.chilterngascars.co.uk/cars/lpgdiesel.htm
That is a mixed diesel/LPG conversion, the engine using both fuels at the same time. This is a well known and effective system.
The second link is simply a vendor selling an ignition system, is there anyone that actually performs the conversion of a diesel to a spark ignition engine on a commercial basis? It's certainly technically possible, but I can think of all sorts of reasons why you wouldn't want to unless there was no other choice.
