I'm hoping some of the knowledgeable people of OcUK may be able to shed some light on a problem I'm having!
I bought this a couple of days ago: http://www.silverlinetools.com/media/manuals/497837_Z1MANPRO1.PDF
It's a butane powered soldering iron (regular lighter fluid) and I don't know what I'm doing wrong but it seems to burn the fuel off in a minute or less!
This is my first gas soldering iron and I've followed the instructions exactly. I fill it up for around 10 seconds, making sure I don't overfill it. I light it but in order to get the flame to a level that is high enough to heat the tip I have to open the valve quite a way, this just results in all the fuel being used up in under a minute. Also, if I leave it at a lower level so as not to use the fuel so fast, then the flame will die down until it extinguishes (while there still being fuel in the container).
Am I doing it wrong, or is it well and truly fubar?
