Permabanned
- 28 Oct 2006
- Bournemouth
some of you might know about my gay fan situation. For those that don't in summarry, it was clogged with dust and was slowing to a halt then spinning slow but making a jet engine noise etc etc. Very annoying and also meant i couldn't game due to it overheating and shutting down my pc.
I had enough of it and i have 'fixed' it
I started by removing the fan to get the dust out of the bearings.....it didn't go as planned.
Luckily i had a backup plan because i kind of assumed fixing it would break it. To the side i had some super glue and an 80mm akasa fan
So i stuck it on, and it stayed on woohoo
Put it in my pc, and i now get better temps than before
