my comp had some problems so now it back to default and i don't remember what to change back to 4.0MHZ OC ...
can some 1 help ? (now i'll write this down to save it)
fisrt i got realy good mem sticks that runs at 1000 ...and a good 60$ cooling for my CPU so ...
so that's all the stuff in the bios : question is what should i change ....
10x !!
first pressing CONTROL f1 - (for the memory timing to open in the bios)
ADVANCE BIOS FEATURE :
changing "cpu enhance halt" C1e to DISABLE
changing "cpu E I S T function to DISABE
MB INTELIGENT TWEAKER :
cpu clock ratio 9X
fine clock ratio +0.5
cpu host clock control ENABLE
cpu host frequency ???
pci - E frequency ???
CIA 2 DISABLE
performance enhance - STANDART
system mem multiplaier - ???
DRAM TIMING SELECTION - auto / MANUAL
if MANUAL :
-cas latancy time 5 auto
-DRAM rast to cat delay 5 auto
-dram ras precharge 5 auto
-precharge delay TRAS 15 auto
-act to act delay 3 auto
-rank write to read delay 3 auto
-write to precharge delay 6 auto
-refresh to act delay 52 auto
-read to precharge delay 3 auto
-static tred value 7 auto
-statc tred phase adjust 17 auto
system voltage control - MANUAL
DDR2 volt control - NORMAL
PCI-E OVERVOLT cnt - normal
fsb overvolt cnt - norMal
G MCH overvlt control - NORMAL
CPU VOLTG CNTROL - NORMAL - default 1.22500V
10x !!
cpu clock ratio 9X
CIA 2 DISABLE
if MANUAL :
