GCSE Maths Question
11 Jan 2004
Hi, this is doing my head in. It's for my daughter and I have no idea how to work it out. It doesn't seem to follow any logic.
Can anyone help? It's for the higher tier GCSE maths (obviously) which she has on Monday!
Thanks,
z
There is a simple formula iirc but im rubbish at maths, hopefully someone will shed more light on it for you. :)
Hope so, this is some dark corner of maths that I've not needed to use for well over 20 years!
Ah, you might want a method. The two trianges are similar as the angles are all the same size, so the only difference is the size of the triangles. They are proportional to each other, so the top triangle has lengths 2/3 as long as the lower triangle. Then just visualise them on top of each other, and multiply by 2/3 or multiply by 3/2 as needed.
Rich1988 said:
I am sure its got something to do with that because its just two equalatral *sp triangles :(
How on earth can they be equilateral, the two given lengths are different?
Ok, got it now.
Blimey, my head really hurts.
Thanks for everyone for their help including ElRazur purely for great entertainment value!
z
Its to do with similar trianges and the ratio of the sides i believe....
CE =
(9/6) * 8 = 12cm (I think)
That should help you work out the rest
zpos said:
Ok, got it now.
z
Do you mind sharing with us please.
I don't know if it has anything to do with it, but just had a look in one of my gcse maths books that i still have lying around 2 years later and it has a help guide at the top of one of the pages. Don't know if it is the same thing as i wasn't too good at maths. I only done intermediate, so it mite be a scaled down version or mite not be the same thing at all of which ignore me. lol
