GDDR and DDR
13 Mar 2011
Bada Bing
i was talking to a friend of mine recently and he wondered why if RAM is so cheap, we cant just use some of it to bolster the VRAM on our graphics cards (we likened it akin to ssd caching :p )
the only thing i could think of is that GDDR might be a different speed to the RAM in which case it might be a pain to get working correctly
but then i thought:
- if DDR > GDDR then why dont we just use the RAM for your Graphics cards?
- If GDDR > DDR then why dont they use the better chips for RAM?
it was all a little confusing which is why im looking for a clear answer here :)
With multi monitor setups, I think we'll eventually see expandable GPU's, where you can purchase extra ram and install it - Extra revenue for the manufacturers!
What, like a Matrox G200 you mean?
rocking it old school
Just thinking the same.
Its not a new Idea, I can remember buying a 2MB upgrade for my Matrox mystique.
It'd be good if manufactures bought this idea back.
I suppose that is all onboard graphics is and windows tries to be with ram assisting the graphics.
I also had an S3 Virge where I upgraded the memory from 1Mb to 2Mb by swapping a socketed ram chip.
right, graphics cards (these days) have the VRAM soldered on, so no you can't
in the olden days you used to be able to with certain cards when they had the modules as an add in but they stopped doing that years ago
even most integrated graphics that use part of the system ram as VRAM have a fixed amount that they will use up to so just throwing in more and more system ram won't allow you to use more of it as VRAM, and I've never seen an integrated chip that will let you use up to 4GB
even the graphics cards that come in 2 different flavours, they do this by replacing ALL of the RAM chips with double sized ones, it's not like they use double the number of chips so you could even plug in extra ones
It would be interesting to see gfx cards with a ram upgrade slot. this should be pretty easy to do but could have a few consequences. VRAM needs to be as close to the GPU as possible so think about physical difference in circuit length, it's also an idea that all ram chips be equidistant from the GPU for timing purposes. What could be more beneficial could be to have a secondary ram cache which could handle the overflow from the primary ram. This may minimize game stutter when the card is struggling to move around textures etc as it would take away a lot of the latency associated with talking to they system ram.
Couldn't you just buy bigger chips and solder them on yourself?
If you cand find someone who could solder CSP then yes (but you can't, they need to be reflow soldered).
All of the surface mount components will be soldered in one pass, and possibly even the through hole components as well, but if not they could be hand soldered at the end of the production line.
im waiting for graphics cards that have flat ram slots like a laptop that you can upgrade the vram :D :p
Aint gonna happen because of the way semiconductor package technology has moved on over the years...
...but you knew that anyway :)
Plus, sockets are expensive and add potential reliability issues.
This could get interesting. Just think, first upgradeable RAM, then upgradeable processor. Soon we'll have a full upgradable graphics computer within our computers!
graphics cards are getting so complex and power hungry, they may are more like a "daughter-board" than a "card" :p
