Got a problem with my focus it’s a 2003 1.6
It’s either Gearbox related or clutch related if the later it’s under warranty but I’m getting conflicting reports on which one it is.
With the car Idling and in neutral if you press the clutch pedal to the floor then release the pedal fairly quick the gearbox knocks and rattles loud enough to hear it inside the cabin.
If you do the same but release the pedal slowly there is no noise.
Occasional; there is the rattle knocking when at cold start, it’s like something is unsettling a bearing or something inside the gearbox or clutch.
Anybody know if this is clutch related or Gearbox related.
Thanks Dutch
Thanks Dutch
