- 11 May 2006
Hi,
I'm not sure if this is a common problem but I seem to get a fair bit of loading pauses and brief stuttering when entering new areas. It's not a huge problem since it only happens once after I first enter a new area but it is annoying nonetheless. The game runs fine at 1680x1050 @ high settings (with highest texture details) and looking at ATI Tools it's using way less than 512mb of graphics memory, so why is it still stuttering when entering new areas? Is there a way to make it load everything to memory? Surely it can't be using more than 2gb of system ram?!
Please note that I've already set "OnlyStreamInTextures" to "TRUE" in the config files and it has indeed solved the constant stuttering you get, but it still stutters/pauses when entering new areas.
My specs are:
X2 4400+
2GB DDR400
X1900XT 512mb
WinXP
Any advice would be greatly appreciated.
BTW, the graphics are awesome and the presentation top notch plus the performance makes my x1900 look brand new, lol. Gameplay is a bit repetitive, but oh well, that's consoles for ya.
My specs are:
X2 4400+
2GB DDR400
X1900XT 512mb
WinXP
