GeForce 177.41 WHQL for GT200's up at Nvidia
Caporegime
8 Jul 2003
In a house
As Title, im ******* shocked here, another WHQL driver for their GTX's already which hasn't taken 6+ months to appear.:eek:
Will work on other cards to more than likely, just add your card into the .inf.
Vista 64bit
http://www.nvidia.com/object/winvista_x64_177.41_whql.html
Vista 32bit
http://www.nvidia.com/object/winvista_x86_177.41_whql.html
XP 32bit
http://www.nvidia.com/object/winxp_177.41_whql.html
XP 64bit
http://www.nvidia.com/object/winxp64_177.41_whql.html
Typical Nvidia, only supporting their new cards.
As far as I was aware, they're never going to do it to support the G80's are they? Thought it was G92's and higher?
Cheers Pug ;)
It was all over their own bulletins on the web that they will "later" support the G80.
I would guess a 8800GTX and Ultra can do more than the lesser G92's with the raw power they have.
The raw power G80 has is not in the shaders, it's in the bandwidth and raster operations, G92 is faster in terms of raw shader power (mostly due to higher stock clock speeds).
Edit: I say that because CUDA only runs on the shaders.
