GeForce 310.33 Beta Drivers
Man of Honour
9 Jan 2007
Metropolis
Dated 23/10, Windows Vista, Windows 7, Windows 8.
64 bit:
32 bit:
Release Notes:
New in R310 Drivers:
•Performance Boost – Increases performance for GeForce 400/500/600 Series GPUs in several PC games vs. GeForce 306.97 WHQL-certified drivers. Results will vary depending on your GPU and system configuration:
GeForce GTX 680:◦Up to 11% in The Elder Scrolls V: Skyrim
◦Up to 6% in StarCraft II
◦Up to 6% in Batman: Arkham City
GeForce GTX 660:◦Up to 6% in The Elder Scrolls V: Skyrim
◦Up to 3% in Batman: Arkham City
◦Up to 4% in Dragon Age II
•Updates 3D Vision profiles for the following PC games:
◦Assassin's Creed III rated Not Recommended
◦Bloody Good Time rated Good
◦Bullet Run rated Fair
◦Call of Duty Black Ops 2 rated Good
◦Carrier Command: Gaea Mission rated 3D Vision Ready
◦Dark Souls rated Fair
◦Dishonored rated Fair
◦FIFA 13 rated Good
◦Hitman: Absolution rated Fair
◦I Am Alive rated Fair
◦MLB 2K12 rated Fair
◦NBA 2K12 rated Good
◦Need for Speed: Most Wanted rated Fair
◦Sniper Elite V2 rated Poor
◦Tiny Troopers rated Fair
◦Tony Hawk's Pro Skater HD rated Good
◦Total War Battles: SHOGUN rated Good
◦XCOM: Enemy Unknown rated Fair
•NVIDIA SLI Technology – Adds or updates the following SLI profiles:
◦Dirt: Showdown – updated SLI profile
◦Dota 2 - updated SLI profile
◦Dou Zhan Shen – updated SLI profile
◦F1 2012 - added SLI profile
◦FIFA 13 – sdded SLI profile
◦Red Orchestra 2: Heroes of Stalingrad – updated SLI profile
•Other Profile Updates
◦Updated NVIDIA Control Panel ambient occlusion support for Counter-strike: Global Offensive
◦Added NVIDIA Control Panel ambient occlusion support for Cross Fire
◦Updated NVIDIA Control Panel ambient occlusion support for Darksides 2
◦Added NVIDIA Control Panel ambient occlusion support for Dragon Nest
◦Updated NVIDIA Control Panel ambient occlusion support for Guild Wars 2
◦Updated NVIDIA Control Panel ambient occlusion support for Mechwarrrior Online
◦Added NVIDIA Control Panel ambient occlusion support for Meng San Guo
•NVIDIA CUDA
◦Includes support for applications built using CUDA 5 or earlier version of the CUDA Toolkit. More information at http://developer.nvidia.com/cuda-toolkit
Additional Details
•Installs PhysX System Software v9.12.0904.
•Installs HD Audio v1.3.18.0.
•Supports OpenGL 4.3 for GeForce 400-series and later GPUs.
•Supports DisplayPort 1.2 for GeForce GTX 600 series GPUs.
•Supports multiple languages and APIs for GPU computing: CUDA C, CUDA C++, CUDA Fortran, OpenCL, DirectCompute, and Microsoft C++ AMP.
•Supports single GPU and NVIDIA SLI technology on DirectX 9, DirectX 10, DirectX 11, and OpenGL, including 3-way SLI, Quad SLI, and SLI support on SLI-certified Intel and AMD motherboards.
Just a question guys, back when Nvidia had that issue with a driver which caused GPU's to over heat, where they beta's?
For this example, lets just say they where, and they broke your gpu, is that covered by warranty?
I would presume that would be classed as normal usage
so yes its covered (IMO)
