geforce 4 ti4600 problem
Permabanned
7 Aug 2005
well untill i get the new pc im stuck with the old one......
now i only play delta force blackhawkdown, but if i turn all the settings on max, the game stutters is choppy and laggy.
now this shouldnt happen as it supposedly runs fine on an 800mhz with a geforce mx, yet i have
athlon xp 2100
asus 333 mboard
512mb ddr 333 ram
7200k hdd
geforce 4 ti4600 128mb gfx
so overkill for the game......
any ideas why its so choppy ??
would psu matter, my original one blew up so i bought another one thing it was 280w or something low....
cheers
athlon xp 2100
asus 333 mboard
512mb ddr 333 ram
7200k hdd
cheers
Could be the PSU, 280W is a bit low (especially on an unknown brand which I assume it is). More likely it is one particular setting that is slowing it down. Start with everything on low, then put each slider from minimum to maximum and restart until you find the source of the slowdown.
Might be something like too much AA on a ti4600...
To be honest, as it is an old game/system this is part guesswork, but that is how I would find the culprit.
