Geforce 7300gs, delay on CS:S (offline delay)
15 Feb 2006
hell
hey,
Just installed my geforce 7300gs, amd 64bit 3800 and 1gig of ram.
Tried farcry and had some weird graphics errors with shadows, and being able to see the frame of underwater plant life.
Also in CS:S, offline mode... i had 100-130 max FPS, but a weird delay as if i was playing on a server with a crap connection. Lets say a half second lag from when i press a direction and the movement taking place.
Anyone know why? any commands or anything in CS to tweak for my system?
if you have V Sync enabled, disable it, i was getting a similar problem yesterday on CS:S and found it to be the V Sync Causing it, not sure if its same problem, was on a 7600 GT
When you play css offline it is a 33tick server. 33tick is what most crap public servers are, so if your on a 33tick you will lag a bit and bullet reg will be crap. 66tick is the minimum server tickrate which is playable. 100tick is the best.
33tick
66tick
75tick
100tick
Those are the tickrates. Higher the tickrate better the bullet reg, should have no lag problems on a 66tick or higher server when online. I dont think you can change the tickrate in offline mode. Unless you have a spare decent machine where you can set a lan server up.
Also if you havent already, you should change your rates to 25000 100 100. So you will get the best possible bullet reg. Just put...
cl_cmdrate 100
cl_updaterate 100
rate 25000
They go in console, or put them in your autoexec.cfg if you know what console is then go to options then keyboard settings then click advanced then tick enable console. Then press ` to bring console up :).
Hope this helped :).
your rates are going to be dependant on your connection and so 25k 100 100 isn't always the best.
Same with 100 tick servers. Most people think they are the best but the majority of 100 tick servers i visit are either setup by retards and capped at 60 or setup by retards on boxes which can't handle the requirements. Also 100tick is only going to offer the best reg if your machine constantly gets over 100fps all the time.
