GeForce 7600 GT
18 Jun 2005
London
I recently bought a BFG 3DFuzion GeForce 7600 GT 256MB GDDR3 and earlier on this evening i was moving the case across my floor, i didnt knock the case but the monitor suddenly turned a tint of bright blue.
The 2nd DVI port is fine and gives off normal colours (monitor is connected with a DVI-VGA dongle)
I've tried pushing the card back in place incase it moved, but this has done nothing. The first DVI port still shows a blue tinge on screen.
Has the card picked up a fault? or could there be a better explanation.
Any help would be appreciated :)
I've had a quick look, would a bent pin be very visable? cant see a whole lot to be honest. The cable wouldnt have moved that much but there is a slight chance it snagged and pulled.
Its not something that bothers me all that much as i'll never use dual DVI, but its just annoying as its a new card and i dont want it to be faulty and for it to happen again :)
Thanks for the welcome. :cool:
