Geforce 8800 GT OC Temps
7 Dec 2007
Hi guys,
What is the normal temps for these cards (Geforce 8800 GT)?
The card comes at (core 626Mhz) and (memory 900Mhz) out of the box, idle temps are around 40oC and after about an hours play, increases to about 60oC. Is this normal? I have never look at GFX temps before so wouldnt know.
Thanks in advance
Damon
No its not normal, auto fan speed is around 50+ idle, and over 85+ load if you have Nvidia's referance cooler of the piddly small fan. :D
Those temps you got there are ideal. :)
oh cool, so maybe I could push her some more then, what speeds you recommend upping to for this GT?
Cheers for the reply
Damon
