GeForce 9600GT Shader clock slow
2 Feb 2006
Chepstow, Wales
Problem.......the shader clock on this card is supposed to be 1625 MHz but will only run at 1600MHz.
My AMD Phenom II X2 560BE(3.3GHz)runs at 3.5GHz so would this be the cause:confused:?
That wouldn't affect it. What are you using to measure the shader clock? Also go into the BIOS and change the PCI-E bus to 101mhz to see if that fixes anything.
