Afternoon,
My recently purchased Asus 9800GT 512MB graphics card came with a software utility called SmartDoctor. This measures the temperature of the graphics chip. I am a little worried at the idle temperature, and want somebody to please re-assure me... or warn me
With the fan set to 100% the idle temp is 63 degrees C. When gaming this rises to 80/85 degrees C. The BIOS on the card has been brought up-to-date (made no difference), and my case is as clutter-free as possible with regards to cables. If I run the PC with the side of the case off, the idle temp drops to 52 degrees C, and no more than 65 when gaming.
Therefore, my main question is - should I be worried?
For reference, my card is the following:
http://uk.asus.com/products.aspx?l1=2&l2=6&l3=656&l4=0&model=2630&modelmenu=1
