I've just upgraded my system from a Q6600 based one to this:
New components: Intel i5-2500k, ASUS P8H67-M (B3), OCZ 4Gb DDR3
Old components: NVIDIA GTX 260, Corsair HX520W, Crucial P64 SSD
OS: W7x64
However my problem is I can't get the NVIDIA GTX260 to work on my new ASUS P8H67-M.
It freezes my system within a few seconds of reaching the desktop after boot. If I don't install the GeForce drivers and just use the Standard Windows VGA drivers, or boot in Safe Mode, it doesn't freeze, but i've tried 3 different Geforce drivers and all have the same problem.
(275.27 (latest beta), 266.58 (latest stable), 197.13 (Apr'10 driver))
I know the graphics card hardware is fine as I've tested it on another system. Everything points to it being a graphics driver issue but I can't yet rule out it being a motherboard issue until I can get hold of another PCI-e card to try (preferably ATI).
Maybe the old GTX260 just won't work on the new motherboard? As I say, I don't have another PCI-e card to try and don't want to buy one when I know my GTX260 isn't faulty.
I've tried clearing the CMOS a couple of times, all drivers/bios are up to date, and I have no reason to think it's power issue based on my spec. I've also done 3 clean installs, same problem each time.
At the moment I'm just using the on board graphics, which disable automatically on this board when a gfx card is present, so I don't think there is a conflict there.
Any ideas?
OS: W7x64
Any ideas?
