GeForce Experience 2.0.1 Release
This update provides critical bug fixes for GameStream including:
•OpenSSL security enhancements for remote GameStream on SHIELD
•Improvements to streaming quality
•Reduction in audio latency
GeForce Experience 2.0 Release Highlights
ShadowPlay
•Adds support for GeForce GTX notebooks
◦GeForce GTX 800M, GTX 700M, and select GTX 600M GPUs supported
•Adds support for desktop capture
◦Requires latest GeForce driver
◦Requires Aero mode enabled
◦Desktop GPUs only
•Adds native 1920 × 1200 capture
•Alt-tab will pause instead of terminate recordings
•Video folders are now created when a video is saved instead of at game launch
•Adds advanced quality options for Twitch streaming
•Twitch streams will automatically be tagged with game name
•Twitch streams now retain capture aspect ratio
•Pause and resume broadcast
•Fixes password handling bugs
•Fixes bug where on-screen indicator cannot be disabled
•Improves microphone audio quality
GameStream
•Wake on LAN support: remotely wake up your PC from sleep mode
•Remote Login support: login to a locked PC remotely from SHIELD
•Manually add games to your GameStream list
◦Go to Preferences –> GameStream
•Remote streaming support (beta): stream your PC games to SHIELD from outside your home
•Notebook GameStream support (beta)
Bug Fixes
•Various stability and bug fixes
http://www.geforce.co.uk/geforce-experience/download
ShadowPlay
◦Desktop GPUs only
GameStream
Bug Fixes
