Trying to get the game to render higher than my current 1920*1200 and then down sample it so I can get a nicer looking game but don't get how this is meant to work? I don't get Isolation in the list of games when opening the GFXP app and not sure if it is working from within the Nvidia CP. Saving screen shots should they not be saved in the res I am rendering at and not the rest it is being displayed at? All my screen shots are 1920*1200 but I was sure I read with this they would be at the 4k resolution.
Thanks
*edit*
Turns out I have just found it, there is no DSR option but you merely change the resolution yourself under the GfXp app. However Isolation is still not appearing in the list which is a tad annoying
Thanks
*edit*
