Geforce Experience Won't Uninstall
20 Aug 2012
Greater London
since i accidently installed Geforce Experience 1.5 (or maybe it came with the update), startup times are slower, even though it doesn't have a startup entry in msconfig.
I know this piece of software causes the problem, as my computer used to boot up slow if Geforce Experience was installed, so i uninstalled it. Then Malwarebytes accidently deleted something that stopped the graphics driver from working, so when i reinstalled the driver, Geforce Experience 1.5 was back, but this time it won't uninstall...
Is there a way to manually uninstall it?
A better way would be to actually reinstall the Geforce Experience, reboot and then try to uninstall it again.
It sounds like the unstaller has got corrupted.
Unless something has seriously gone awry that should work.
