GeForce GTX 570
18 Apr 2009
Hi guys,
Need some advice on on a graphics card upgrade. Due to the GTX285 carshing all the time.
Anyways, I would be very greatful if you can let me know if i can swap the 285 for the 570 considering I have a Cryo Nano PC case?
Thanks in advance
Core i7 920 D0 stepping 2.66GHz - Cryo Boost 3.9GHz+
Corsair 64GB SSD, Extreme Series X64
Corsair 850W single rail, max current 70A+
High Performance Air cooling
Lian Li PC-V351 small form factor case
MSI X58M mATX
NVGTX285
nVidia GTX 285 1GB
PC3-12800C7
Corsair 1600MHz PC3-12800 3x2GB
SH-S223F
Hi, having owned both cards I would say length wise you should be fine. In terms of height it realy depends on the model of 570. The Direct CUII for instance is a monster taking up 3 slots where as the MSI Twin Frozr only takes up two it all depends on the model you go for.
@eggcup, how about the Elite 335? any idea if this will fit in that case? There is nothing "below" the graphics card so i imagine the triple slot size won't matter in that respect?
