Hi there
It is with great pleasure that the first GTX 980 custom designs will be arriving from as early as tomorrow if no courier issues. This is far sooner than we were expecting.
As such the following are all arriving within a two week period.
MSI GeForce GTX 980 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card @ £469.99 inc VAT
The new NVIDIA GeForce GTX 980/970 is powered by the next generation NVIDIA Maxwell Architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features.
Maxwell is the most advanced GPU architecture ever made, designed to be the engine of next generation gaming. Inspired by light, it was designed to solve some of the most complex lighting and graphics challenges in visual computing. For the first time, gaming GPU's can dynamically render indirect light using the new VXGI (Voxel Global Illumination technology). Scenes are significantly more lifelike as light interacts more realistically in the game environment.
The GTX 980 is the worlds fastest GPU and the GTX 970 offers the most advanced performance in its class. Each delivers 2x the performance of previous-generation card, bringing new gaming experiences to virtual reality, and ultra resolution 4k displays.
Enable the detail of 4k monitors, on a 1080P display. DSR produces smoother images by rendering a game at a high resolution, then downscaling it to the native resolution of the display using advanced filtering.
GeForce GTX 980 and 970 cards support tear-free, super-fast NVIDIA G-Sync monitor display technology including 4k. Together, these technologies provide the most immersive and competitive gaming experiences possible.
Features:-
- Voxel Global Illumination Technology (VXGI)
- NVIDIA® Super Resolution technology
- NVIDIA® GameWorks technology
- NVIDIA® GameStream technology
- NVIDIA® TXAA Technology
- NVIDIA GPU Boost 2.0
- NVIDIA PhysX® Technology
- NVIDIA FXAA Technology
- NVIDIA Adaptive Vertical Sync
- NVIDIA Surround
- Support for four concurrent displays including: Two dual-link DVI, HDMI and DisplayPort 1.2
- Microsoft DirectX 12
- NVIDIA® 3D Vision® Ready
- NVIDIA SLI® Ready Technology
- NVIDIA CUDA® technology
- PCI Express 3.0 support
- OpenGL 4.4 support
- OpenCL support
- NVIDIA SHIELD Ready
- NVIDIA G-Sync Ready
Specification:-
- GeForce GTX 980
- GPU: GeForce GTX 980 (GM204)
- Core Base Clock: 1216MHz
- Core Boost Clock: 1317MHz
- Memory Clock: 7010MHz
- Memory Size: 4096MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 256-bit
- CUDA Cores: 2048
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 500W PSU Required
- 200W TDP
- Warranty: 3yr
Only £469.99 inc VAT - Best case Friday 26th, worst Monday 29th September
ORDER NOW
Inno3D GeForce GTX 980 "Herculez X3 Ultra" 4096MB GDDR5 PCI-Express Graphics Card (N98V-1SDN-M5DNX) @ £429.95 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- Core Base Clock: 1152MHz
- Core Boost Clock: 1253MHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Dimensions: 268.6 x 98.4 x 40 mm
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 2yr
Only £429.95 inc VAT - Due end of next week!
ORDER NOW
Gigabyte GeForce GTX 980 G1 Gaming 4096MB GDDR5 PCI-Express Graphics Card **OcUK Exclusive** @ £499.99 inc VAT
GIGABYTE WINDFORCE 3X 600W cooling system once again break the record and bring the air cooling capacity up to 600W by only using 2 slots heights. The WINDFORCE 3X 600W cooling system is equipped with five 8mm and one 6mm composite cooper heat-pipes , special fin architecture, unique blade fan design, and GIGABYTE “Triangle Cool” technology. This not only provides an effective heat dissipation capacity but also enables higher performance due to a lower temperature.
GIGABYTE Flex display technology can automatically detect any connected monitors and achieve multi-display gaming up to 4 monitors at the same time by using various output groups. Users could enjoy the best gaming experience in ultra HD resolution with extended flexibility in arranging monitor configurations and making future system upgrade extremely easy.
With GPU Gauntlet™ Sorting, the Gigabyte SOC graphics card guarantees the higher overclocking capability in terms of excellent power switching. Ultra Durable VGA board provides dramatic cooling effect on lowering both GPU and memory temperature by doubling the copper inner layer of PCB. Ultra Durable VGA board reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability. Ultra Durable VGA board allows more bandwidth for electron passage and reduces circuit impedance. The less circuit impedance, the more stable flow of current and can effectively improve power efficiency.
Features:-
- WINDFORCE 3X 600W cooling system
- Flex Display Technology(patent-pending)
- Powered by NVIDIA GeForce GTX 980 GPU
- Integrated with industry's best 4GB GDDR5 memory 256-bit memory interface
- Features Dual-link DVI-I / DVI-D / HDMI / DisplayPort*3
- BASE: 1228 MHz / BOOST: 1329 MHz
- System power supply requirement: 600W(with two 8-pin external power connectors)
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- Core Base Clock: 1228MHz
- Core Boost Clock: 1329MHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 1x DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Dimensions: L=312mm, W=129mm, H=43mm
- Power: 2x 8-Pin
- 600W PSU Required
- 220W TDP
- Warranty: 3yr
Only £499.99 inc VAT - Due end of next week!
ORDER NOW
Inno3D GeForce GTX 980 "iChill Herculez X4 Air Boss Ultra" 4096MB GDDR5 PCI-Express Graphics Card (C98U-1SDN-M5DNX) **OcUK Exclusive** @ £479.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- Core Base Clock: 1266MHz
- Core Boost Clock: 1367MHz
- Memory Clock: 7200MHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
Only £479.99 inc VAT - Due in two weeks!
ORDER NOW
VOLUME OF REFERENCE 980 DUE WITHIN 1-3 DAYS
GALAX GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card (98NQH6DHXXXX) @ £431.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- Core Base Clock: 1127MHz
- Core Boost Clock: 1216MHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 2yr
Only £431.99 inc VAT - 200 Due early next week!!
ORDER NOW
Inno3D GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card (N980-1DDN-M5DN) @ £425.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 2yr
Only £425.99 inc VAT - 500 Due tomorrow!
ORDER NOW
MSI GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card @ £469.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
Only £469.99 inc VAT - Due tomorrow!
ORDER NOW
So in the next 1-3 days we have 500+ GTX 980's arriving including custom designs. As always OcUK shall be first and has the most stock!
Right now we have in stock GTX 980 from EVGA, Gigabyte and OcUK model! We have 100's of 970's now in stock also!
Lastly check out that Inno3D GTX 980 Ultra X4 Air Boss, it is the fastest out of the box GTX 980 with nearly 1400MHz boost clock, WOW!!! Oh exclusive to OcUK as well and Gigabyte G1 980's should be here end of next week which should prove a great clocker too.
Get spending guys, OcUK has the most stock incoming, the largest range available including the largest in stock range of 9xx series.
LIKE A BOSS!
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 500W PSU Required
- 200W TDP
- Warranty: 3yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 2yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 600W PSU Required
- 220W TDP
- Warranty: 3yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 2yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 2yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
ORDER NOW
LIKE A BOSS!
