Geforce RTX 2070Q
i have a razer blade with a 2070 max Q and so far it run everything smooth, that's with the power brick connected which is 230w so its getting enough juice when playing. If you are using it for gaming it does get hot given how thin it is, and it has the new vapour chamber. I am guessing most the laptops with the 2070q do get hot its just down to the cooling system they use, also i will say look at what wattage the power brick is. I had a dell G7 with a 2060 using a 140w power brick and you could see that the card wasnt getting enough power.
Whats your verdict on the razer blade with the 2070 ? Happy with it and the build quality ?
I have an HP Omen 15 2020 model with a 2070 max Q, can’t fault it, performance and thermals are excellent so far.
