- 2 Nov 2005
Hello.
Last week I bought a load of bits from OCUK and I'm having trouble getting the RAM to work at the right timings.
I have an Asus P5N32E-SLI mainboard running an E6600 @ (stock) 2.4GHz.
The memory is GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel.
On default settings the BIOS sets the timings at 5-5-5-18 @ 1.85v. With these settings the memory is completely stable and runs at the correct speed of 800MHz. However GeIL rate this RAM at 4-4-4-12 @ 2.1v but as soon as I change any of the settings the PC locks solid within a minute or so of booting.
The FSB:RAM ratio is 2:3 (266:400) but I've tried linking and unlinking this and it's made no difference.
It's not a huge deal - if I have to run it at the slower timings then so be it - but it would be good to be able to run it at the manufacturer's recommended timings.
I could accept the system freezing if I was trying to overclock but I haven't even got that far.
I've read a few threads on here about people having similar problems but as yet (AFAIK) no one has found a solution.
Any ideas? TIA.
Any ideas? TIA.
